FlowVis flow meter body cracked
Hi,
It seems my FlowVis was the only thing damaged by the recent Texas freeze. I can see a crack in the body, but the meter itself seems fine. I'm wondering if I could just install the meter into a Jandy check valve body. I know they sell a retrofit kit for this, but I can't find if the retrofit is the same part that comes with their non-retrofit meter and body. Anyone have any ideas?
David
It should work. Buy a check valve and test the fit. If I am wrong you can always sell the CV.
Thanks guys!
I ended up calling H2Flow to inquire. Apparently it does fit the Jandy CV body, but alters the scale. They are sending a replacement label for the meter that will adjust for the Jandy body. Sticker was free, replacement FlowVis CV body ~$40. I chose the sticker because I already had a Jandy body laying around.
Thanks guys!
Thanks. Good tip to know.
