Hi All,
I want to prevent my Stenner pump (for MA) from ever running when there is no flow. I read this thread but I want to do it differently if possible and hopefully simpler.
www.troublefreepool.com
I am thinking of using a relay to open/close the outlet's cricuit where the pump is plugged. I found this particular relay which powers itself from the 110 V side to the 24v input. (Based on the single review, seems to be the way I would need it to open/close):
www.zoro.com
This would be the flow switch (same as in the above thread):
Did anyone attempt to do it this way? Or is there a simpler way?
Any guidance is appreciated.
Allen
Controlling Stenner with a Flow Switch?
I have a Stenner Econ T for Chlorine injection that I want to control with a flow switch. i am concidering using the following switch: https://www.amazon.com/gp/product/B01MR8371I/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 but I haven’t been able to locate any specs on the switch. The Stenner...
Functional Devices Inc / Rib CLC212 $26.39 Closet Light Controller, Door, Gray, 120VAC | Zoro.com
Order Functional Devices Inc / Rib Closet Light Controller, Door, Gray, 120VAC, CLC212 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
Amazon.com: BLUE WORKS Flow Switch Compatible with Hayward Goldline Systems, Flow Sensor with Tee: Garden & Outdoor
www.amazon.com
Allen
