Dirk: yeah i called the water company the lady had zero clue. Said someone would call me. I agree that it's well worth the money spent to know precise numbers. I will order the one you sent over right now
Thanks Dirk!
PS - I would be happy to sell this or use a "pool" of people that want to use it. We do that in aviation. Instrumentation is quite expensive and 4 of use pitched in to buy a certain instrument and we use it as a spare while ours is being rebuilt. Never had to use it but it's a good way to help out like minded people!
Dirk - do you know the average size of a hose bib? I just measured and it seems to be less than 1 inch
Hose bibs are usually 1/2" or 3/4". The meters come in sizes, too. 3/4" is about $15 more, I think. Depends on how fast you need to fill your pool. Might have more to do with the hose(s) though, than the meter.
3/4" is not 50% more than 1/2". It's more like twice as much flow. I'm still learning hydraulics, but I thought I've read that a single pinch point doesn't govern flow, but rather the water will speed up through it. It's more about the diameter of the entire run. So if you had three setups:
A: 1/2" hose to 1/2" meter
B: 3/4" hose to 1/2" meter
C: 3/4" hose to 3/4" meter
The GPM of B would be closer to C than to A.
Point is, no matter what meter you choose, the bigger the hose to it, or the more hoses to it, the better. You're going to need some PVC adapters to go from the hose to the meter. Lowe's would have 'em. But if you can stretch 2 or 3 hoses to the meter, then build an adapter that'll connect all three hoses to the meter. That's if you're in a hurry. If not, then don't worry about any of that. If it's hot out, though, don't dawdle. Plaster suffers in hot weather.
So don't worry about hose bib size. Run 1, 2, or 3 hoses to your new meter. Given this is new plaster, I'd use the 3/4" meter.
But, be sure you have some way to get the output of the meter down to the very deepest part of the pool without the water running down or splashing the side. That's really important. That's
really important. You could use a hose on the exit side of the meter, but that will choke the flow if you have more than one hose coming in. I used my vacuum's big 1 1/2" hose, affixed to the end of the meter, then over the side to exit into the bottom of the deep end.
Whatever you do (I'm going to shout): ONCE YOU START THE FILL, DON'T STOP IT FOR ANY REASON!! If you halt a fill, you can leave a permanent ring at that level. So:
Fill from the very bottom, as fast as you can, in one continuous shot.
Take a photo of the meter before and after. It's easy to mix up the numbers. A photo doesn't forget. Mark where you want the fill to stop with a piece of tape. The rule of thumb is halfway up the opening of the skimmer. But it's deceptively hard to see where that is when there's water in the skimmer, because of the water's refraction. Best to mark half way (or wherever your PB tells you "full" is) with a piece of tape.
There... that'll keep you busy!
