- May 25, 2018
- 20
- Vinyl
- CircuPool RJ-60 Plus
I am about to replace all the valves for my pool and therefore a good chunk of the plumbing (as you can hopefully see in the pictures). The existing valves are brass, hard to open/close, and some of them rotate as they are no longer secured (which they shouldn't and I believe is adding air into the system). I purchased 7 never lube valves from a local supplier and have them ready to go. Replacing the 4 on the suction side should hopefully be straightforward (i.e. cut out the plumbing and put it back as it is but with 4 never lube valves). (It's also worth noting that I switched to a robotic pool cleaner since the pressured side vac doesn't seem to get enough pressure to clean).
I'm not sure exactly sure what the best way is to configure the plumbing on the pressure side, after my (ancient) electric pool heater. The pool frog system right after the heater will be removed and somewhere in this area (just after the heater) is where a potential SWG would go. Since I will be replacing the 3 valves here (1 on the right side goes to the waterfall, the other 2 practically in the ground go to a bench), I have the opportunity to completely reconfigure this portion. I've seen several examples where they have come down at a 45-degree angle vs. the 90 that I have leading into the pool frog. That seems to allow for a longer straight run before the water heads to the pool.
I plan to DIY this. The actual plumbing work is fairly simple and I have done plenty in my lifetime. But I could definitely use some advice on most effectively configuring it. Happy to post some additional pictures or create some mockups as needed.
Thanks in advance!
Thanks in advance!
