I have never had to use well water to fill a pool before and was unaware of all the issues associated with using a well. I have attached pictures to illustrate my point later but the summary is I need advice on how to proceed from this point. Everything I am currently doing seems to help but only marginally. I filled my pool and noticed a brown tint to the water. My wife and I did some research and discovered it was iron in the water. As we were unprepared for this we decided to empty the pool to start over. I stopped draining it around a foot deep and wanted to see if brushing and vacuuming would help. That was five days ago and my pool still looks like the pictures. The brown comes off when I go to brush it but it seems like the vacuum is having minimal effect. Should I drain it completely and hand clean everything (using Vitamin C or other suggested cleaning methods) or should I continue what I am doing until I get it all out? The first image is what happens after I brush and the second image is how it looks after everything I have brushed settles (usually in between changing out brush and vacuum).
