- Jun 8, 2019
- 4,574
- Vinyl
- Pentair Intellichlor IC-60
Sounds like you may have overshot a little. Round up to the nearest 10 for CYA tests as the scale isn't linear - so you consider your pool to have 60 CYA. No more pucks or tri-clor / di-clor, as you mentioned. You mentioned before you put in solid granule CYA, and then you also added liquid as if you were at 0? If so, that could be the reason it was overshot.
Not sure if you did the overnight test yet - did that pass?
