Hello everyone! Hoping a newbie can get some help with next steps. It's been a few weeks since we fired our pool cleaning company, they would occasionally no-show, I don't think they were taking any measurements and just threw a fixed amount of 'shock' in the pool every single week. I was a little slow on figuring out next steps before deciding on the TF Pro Test Kit, and here we are now. After running all the tests for the first time, this is what I've got below. Given the CH and CYA recommended actions, I assume the best course of action is to FIRST drain most of my pool water and then re-fill it, correct? Then redo the tests and see what the recommendations are at that point to re-open the pool basically?
Current CH: 1,000 / Target CH: 450
Calcium hardness level of replacement water in San Antonio, TX is 175 as measured from my tap (357 according to the internets, generally in my city).
Recommends replacing 86% by volume of pool's water to reach target.
Free Chlorine
100 CYA
Current Free Chlorine: 7 / Target Free Chlorine: 11
7.5% Bleach 121oz bottles... recommend adding 144oz by volume to reach target.
pH
Current pH: 8.2 / Target pH: 7.6
Current Total Alkalinity: 170
Muriatic Acid 31.45% - 20* Baume
Add 49 oz by volume to reach target.
Total Alkalinity
Current TA: 170 / Target TA: 70
To lower TA you reduce pH to 7.0-7.2 with acid and then aerate to increase pH
** Aerate? Like... pump on high for a while?
CYA
Current CYA: 100 / Target CYA: 45
There is no chemical to lower CYA levels .Draining some water and refilling can help lower CYA.
Free Chlorine
100 CYA
pH
Total Alkalinity
CYA
