First time user
sandycoyman
3
Deerfield Beach FL
Having trouble finding where in the pool math ap I can find my SLAM chlorine level. I have entered my pool parameters and my first set of readings. I cannot find how to calculate and find my SLAM chlorine level to address a relatively small outbreak of brown/green algae. Help!
Tap the fc card then move the slider next to where it says SLAM.
be certain your cya level is entered correctly so it populates the correct slam level
Also see —> FC/CYA Levels
Hey Sandy and Welcome !!!
The new version has a checkbox.
For future use, slam target is 40% of your CYA.
Reactions: Mdragger88
Thank you both responding so quickly. My CYA is 70. I need to add water to bring up the water level, so I will do so and then recheck the CYA. Then I will get a new chlorine amount to SLAM my pool. Just to be sure the level I should enter for my SLAM target level at a reading of 60 CYA = 24?
If it reads anywhere between 60 & 70 call it 70.
Always round up if between two marks on the test for chlorination purposes.
Incase you need it handy here’s the guide
SLAM Process
