Just starting the transition from traditional pool store pool management to the TFP method. My TF-100 test kit came in today and I’m pumped!
Tested the chlorine and PH and they both were about what I expected and what the pool store told me when I got it tested yesterday. Low end of FC and high end of PH.
I then did the TA test. It took 16 drops before the solution finally turned red. That gives me a TA of 160. I know TFP hates pool store tests, but it’s been very consistent and following a downward trend over the past few weeks 69, 60, 52. 160 vs 50 seems too massive a difference to not be some sort of issue on my end.
I haven’t ran the CYA test, but the pool store has shown readings right around 80 which also checks out (I used to use tablets).
I’m in Phoenix, so there are tons of pool stores. Would it be worth getting the water checked at another store to at least have some other results to compare to?
