So, I'm getting ready to start-up the system for the first time. Should the return side valves be closed before priming the pump the first time, or should the return valves be open?? The start-up instructions state the following (from the manual) See text in red if a priming problem occurs. It says to open the return valves if there's a problem.
1. Open the High Flow™ manual air relief valve until it snaps into the full open position (this only requires a quarter turn counterclockwise). Opening this valve rapidly releases air trapped in the filter. 2. Stand clear of the filter tank, then start the pump.
3. Close the High Flow™ manual air relief valve after a steady stream of water appears.
4. The system is not working properly if either of the following conditions occur.
a. A solid stream of water does not appear within 30 seconds, after the pump's inlet basket fills with water.
b. The pressure gauge indicates pressure before water outflow appears. If either condition exists, shut off the pump immediately, open valves in the water return line to relieve pressure, and clean the air relief valve, see Section F. Cleaning the High Flow™ manual air relief valve.
Before initial start-up & priming should the return valves be closed??
Thanks, Bob
Thanks, Bob
