I have been reading different articles on this site and have also read the manual on my new Taylor 2006C. Second time testing and my levels appear to be really high. FC=19 CC=2 (I believe this to be correct as my sample never turned red but pink) TA=200!!!! PH=7.2
So I believe in the Taylor instructions it says take care of the TA first then PH and then Chlorine. Well my PH is fine....and in my Taylor instructions it says to use Muriatic Acid to lower TA but your site I believe said using MA to lower your PH which I don't want to do. I can figure out the measurements of how much to use to lower but I guess I want some guidance on 1.) Should I attach TA first and use Muriatic Acid?? 2.) Then move to PH if step 1 lowers my PH? 3.) By doing step 1 and possibly 2 will this fix the chlorine or what do I do to lower that?? New pool owner and my pool company is zero help...they keep having me add algecide and pool complete and our hair is turning green so I know that is not what I should be doing. I want to learn how to maintain without having to add all these extra things causing problems.....
