Hey all,
I just bought a house and opened the pool to find it was green. 2 months prior during inspection, it looked relatively clear. I tested my CYA levels and it reads 100+. Looks like the only way is to drain the pool to dilute it. Can someone give me pointers on this?
Do I set the pump to the drain setting? And I assume I can attach a hose and snake it to my driveway to dump into the street right?
I have a 26,000 gallon pool. How much should I expect to drain?
And if I use the pump to drain it, what happens when the water goes below the skimmer?
During this time, should I be doing anything about the algae? I assume the CYA levels need to be between 30-60 ppm before I can start the SLAM process to get rid of it right?
Any and all tips are appreciated. I apologize for the flood of questions. Just overwhelmed with house ownership in general.
