Hello all....semi long time lurker, first time poster.
We moved into a house this winter that has a pool, never owning a pool before I was hesitant on the maintenance but after a few missteps at first and some google searches I came across TFP and am confident I can do this myself.
First off I ordered the TF-100 test kit but used some test (guess) strips to get a basic idea of where the pool was before it arrived. I had fought an algae issue before finding TFP and am sure my efforts to correct that led me into the fist issue. Clorox Test strips and App put my CYA at around 250 (likely due to the pucks left over from previous owner and shock I used to kill the algae), so after about 4 partial drain and refills I am sitting at 50 - Confirmed with TF-100 test. So my first set of readings with the test kit are below:
FC 6.5
CC 0.5
PH 7.8
TA 110
CH 200
CYA 50
So, looks like TA is high, CH is low...any particular order to tackle those? I also see some occasional algae on the walls, should I SLAM the pool, if so do I get TA and CH to the right levels and then SLAM or SLAM first then retest and go from there...
FYI - The pool has some staining in the deep end and a decent amount of white residue (assume scaling) on the water line tile - I'll tackle these at some point but want to get the basics down first.
FC 6.5
CC 0.5
PH 7.8
TA 110
CH 200
CYA 50
