- Jun 24, 2021
- 16,667
- Vinyl
- CircuPool RJ-60 Plus
Nope. Gear upper right, enable CC and enable share with TFP.I imported everything. Should work now!
I'm not sure what you are concerned about. I provided guidance in post #10 on how to do acid additions to lower pH. Lowering by .4, waiting 30 minutes, testing, lowering again if necessary.Be careful with muriatic acid, you have a plaster pool. Don't add large quantities at a time - divide the calculated demand by 2, wait at least an hour after adding and test. Proceed according to the result.
ThankBe careful with muriatic acid, you have a plaster pool. Don't add large quantities at a time - divide the calculated demand by 2, wait at least an hour after adding and test. Proceed according to the result.
ok. I got the membership transferred over to should be working now.Nope. Gear upper right, enable CC and enable share with TFP.
I have to go get more chlorine. How many more gallons do you suspect I need?Great, for now, also log your chemical additions so we can see those.
Add again to get from your 2FC to 10FC, 30 minutes pump running and test. Only need to test FC.
Continue to do the adds every 30 minutes until your FC is between 5 and 10. Then stop with the additions
I bought 17 more. Can I add in more than the project 10ppm in the beginning so i don’t have to keep adding 3 at a time?I have to go get more chlorine. How many more gallons do you suspect I need?
Shoot. I missed this message. I added 6 gallons 10 minutes ago. Will share the reading in 20 minutesNo. We are trying to eliminate the ammonia. If you add too much, we can do harm.
Just added 4 more gallons.I'm not upset, but there is generally a method to our madness.![]()
We use processes to keep pool, equipment and people safe.
More is often not better, like this situation, or during SLAM. It will be fine, no worries.
Ammonia - Further Reading
www.troublefreepool.com
Ok. I think I’m making progress! Check out my info!Just added 4 more gallons.
OK. Now we stop this process and start the SLAM process.Ok. I think I’m making progress! Check out my info!
Got it. I’m assuming I can start it tomorrow? Also, I checked my CYA, they are still below 30. Is that normal after what I just did?OK. Now we stop this process and start the SLAM process.
Here are the directions. Link-->SLAM Process
Under the first bullet in "before you start" there is a link to a printable checklist.
Read the article, then print the checklist and start the SLAM process.
Yes, that CYA got converted into ammonia, the ammonia was removed by the chlorine.Got it. I’m assuming I can start it tomorrow? Also, I checked my CYA, they are still below 30. Is that normal after what I just did?
No, leave it, you want it low for the SLAM.I also checked the ph, it looks like 7.1, is there anything I can do to bring it up?
Yes! When you start it up, run the pump on high and not clean pressure. During SLAM, you want to run your pump on low speed, filters better. Every couple hours, run on high speed and note pressure. When pressure rises 25%, clean the filter again. You may be doing lots of filter cleaning.I’m noticing my flow is a little slow, can I do a backwash on my DE before I slam?
I was concerned about CSI. Currently in my pool, if I lowered the PH from 7.8 to 7.4 the CSI would drop to -0.70. Probably in the OP case it won't matter much - with his TA the PH will rise pretty quickly.I'm not sure what you are concerned about. I provided guidance in post #10 on how to do acid additions to lower pH. Lowering by .4, waiting 30 minutes, testing, lowering again if necessary.
