Unlikely. With a TA of 90, the pH will rise on its own. And the CYA does not lower pH all that much.Might I need to also get some Borax to bump the PH back up before I leave?
No need to rush it. The FC should start to fall on its own, especially as the summer approaches. After a few days if you are still concerned the SWG is putting-out more FC than you need, you can always adjust the output or pump run time accordingly.According to the FC/CYA chart, my FC is much higher than it should be. Shouldn't I try to get it closer to the ideal level?
I use knee high panty hose type things, fill em up, tie em off and hang them my husband calls them the pool balls socksA 50% starting point should be sufficient. Occasionally an owner will say they are struggling with getting stabilizer to dissolve. Not sure is it's a brand thing or what. I use a regular tube sock, let it soak for about 30 minutes, and it squeezes out like a cloud from the sock in a few minutes. Marty gives some ideas above you can try. Or you can try soaking that sock in a bucket of warm water and squeeze after about 30 minutes in that bucket to see if it will pre-dissolve better for you.
I think that depends on how you do the test, I don't find it really subjectiveI hadn't measured the water in a few days so I took a full set of readings:
FC: 5.5
CC: 0
pH: 7.5
TA: 90
CH: 150
CYA: 50
Still letting the FC start to go down with a lower SWG setting so I think that's fine. TA is starting to drop so that's probably fine too. CH seems low, but I've read I don't need to worry about that much since my pool in vinyl, so should I care? And lastly it seems my CYA has gone down. It has rained some this past week, but not that much. Is it likely it has actually gone down and I should add stabilizer? Or is it just testing inaccuracies since that test is somewhat subjective?
