- Jun 4, 2024
- 201
- Fiberglass
- Pentair iChlor 15
Water temp is hovering around 40 and we have warm spell this week and wanted to start a soft opening (run robot, connect pump, start circulating, etc). I know I can't activate the SWG until temp at least over 60 (iChlor manual says 55 operating temp). And I don't believe I should be running the heater until the water temp is also over 60 (condensation at lower temp, etc).
Should I just plan to vacuum/filter, then take a chemical reading for CYA and start using pucks until temp is adequate to run heater and SWG? From what I'm reading/understanding, the low temp will cause the pucks to dissolve slowly but still need to monitor overall CYA addition. Will be using 3 inch pucks (8oz). CYA was 50 at close and anticipate further loss during winter... I could safely start with 8 pucks (3ppm CYA/puck). Will I obtain fairly accurate CYA with low water temp to know exactly how many pucks I can use overall before switching over to chlorine?
Salt level would then wait until temperature at operating level for heater/SWG... which is when I would check salt level and make any further additions... correct?
And final question... I'm about 4-5 inches below normal fill level. Water is just barely spilling into skimmer. Assuming I should only run main drain until water level higher before opening valve for skimmer drain?
Any other advice greatly appreciated.
