Hello everyone - We built our second pool in 2016. We've only used Muriatic Acid, Baking Soda (Borax, rarely) and regular liquid chlorine to manage our pool. I've never had an issue balancing the water. It seems like around the same time that our ozonator stopped working, I've been having an issue with balancing the water. Today I kind of freaked out because when I tested the PH, the water turned neon yellow. It is normally bright pink and I use muriatic acid to bring the PH down. When I tested for alkalinity, it turned red right away on like 2 drops.
I went to Leslie's and they told me to add the entire 5 lb bucket into my pool, which I did. I'm supposed to add Instant Conditioner Plus in 4 hours.
Should I not have done this? I'm so worried and don't really know what to do as my numbers have never been like this. Please help
Thank you in advance!
Judith
Judith
