First Time Drain
bpdunlv
Active member
Apr 4, 2017
40
Las Vegas
It probably won't have the PSI to unravel the stretch hose. Upgrade to the 1/3 Hp pump as they take TIME to drain the full pool. Or consider renting a commercial pump from Home Depot (etc) to be done in an afternoon.
Your long hose will be the weak link here if you buy a submersible. I hacked mine using 1 inch sprinkler pipe for much better flow, seen here.
Those flexible no kink hoses that shrink up have a smaller inside diameter then regular hoses and will have a lower flow rate. A garden hose already chokes down a pump and lowers the flow rate and increases the pump time to drain the pool.
It will work but not well.
