Hi, everyone, and thanks for this awesome resource!
So, I inherited this above-ground pool without ever having had any kind of pool before, and it's great.
When we first set it up, I did the rookie move and had it tested at not even a pool supply store but a first-responder store that also happens to sell some pool supplies, plus I was trying to use test strips, so although my pool stayed crystal clear for about a month, I was never able to register any chlorine at all, even after dumping in 4x the amount recommended.
I do now know that some of that may have been because I never added CYA, so in the process of starting over, the TFP way!
So we drained, vacuumed, scrubbed and refilled the pool two days ago after receiving the test kit.
Besides the water, only about a quart of chlorine has been added so far, and I did my first test today for practice (results in signature).
Some questions:
1. How accurate does the gallon measurement need to be to "do it right" using the test kit? As many people seem to have experienced with Intex pools, the pool calculator you guys recommend comes out with a slightly different measurement than the Intex number, and I don't want to mess it up with such a basic thing.
2. The test kit I received just says "rinse your equipment before and after each test." I hope this isn't too silly a question, but when I went for the kitchen sink to do this, husband recommended I "rinse" with the pool water, THEN fill the appropriate bottle, THEN test that water. Is that right, or should I use tap water (we don't use softener), or does it not matter?
3. Please see signature for chlorine. Is this a high enough concentration? If not, what is the correct concentration?
4. My CYA is due to arrive in 4 days, as I forgot to order it when I ordered the kit. The pool has just a tiny bit of chlorine that's been added (and measurement is in signature); do I need to add more (and how much?) to maintain it until I'm able to add and test the CYA (I've read here that the powder form can take 3 or 4 days to register on the test, too)? I don't want to waste all that effort and water by neglecting it while we wait for the CYA.
Thanks, all, and any signature line or other feedback welcome!
Scout
Some questions:
Scout
