I just got my test kit and did the full battery (I think). Results:
FC: 1.5
CC: .5
TA: 150
Ph: 8
CH: 1
CYA: 40
Pool: ~30k gallons, vinyl.
I used pool math to calculate bleach addition, and addition of low n slo I still had. I have read the ABC’s of Pool Chemistry and most of the articles in the 101 area / getting started.
Questions:
1) The first time I did my CYA test, I noticed that I added a bit too much solution to top off the bottle. Probably 2 cm? When I ran the test, my result was 20. So, I did the test again being sure to get the levels of liquid as close as I could, and the result was 40. Does that difference sound right? Should I test again tomorrow? How critical is the exact liquid amount for this test? The disparity between those two tests concerned me (largely out of ignorance) so I’m asking to ensure I’m not doing something wrong here.
2) I still don’t quite understand CC. Is the fact that it is .5 a problem? I added 128oz of 12.5% bleach (sodium hypochlorite), which is what pool math told me to do. But, I just wanted to make sure that I don’t need to do anything else.
Thank you!
FC: 1.5
CC: .5
TA: 150
Ph: 8
CH: 1
CYA: 40
Questions:
Thank you!
