First test with TF-100
Jun 20, 2017
12
Rochester, NY
Well, I did it. Just got my kit delivered today and I gave it a shot..Easy to follow instructions and here are my results:
Chlorine 0.5
CC 0.5
TC 1.0
CH 350
TA 100
CYA 50
pH 7.5
Pool came with a Frog... I know... But I'm using it for now so my chlorine is supposed to be low.
Other than that, everything looks pretty good.
Doug
The Frog does not mean that the chlorine is supposed to be low. Their claims are that you're allowed to use a lower FC level. However tfp would disregard that advice and maintain the proper FC levels depending on your cya level
Second test with TF-100
I did another test. here are the results side by side with last week's numbers
Chlorine 0.5 2.5
CC 0.5 0.5
TC 1.0 3.0
CH 350 350
TA 100 100
CYA 50 45
pH 7.5 7.2
I did bump up my chlorine a bit. That seems to be better, but my pH is getting lower. Still in the ok range, but getting close to needing attention.
The kit works great. Way better than just my old chlorine/pH kit.
Here's a question. I did use the daily Chlorine/pH kit (contained in the TF-100) first and got a chlorine level of 5. Then using the more involved chlorine test in the TH-100 kit I got a number of 2.5. Could the quickie test be that far off? Or is there enough possible error on both tests the explain the difference.
Doug
