Hello,
My pool was filled 7 days ago and I was given no instruction on maintenance of new plaster. Luckily I found you guys and finally received my TF-100 in the mail. I also downloaded the app to log my results. My pool school is scheduled for the 30th, so my PB is not officially done.
So far I have only added acid for ph maintenance and brush twice daily. My pump is running 24/7, 16 hours on low and 8 hours on high. When should I start decreasing run time?
FC 4
pH 7.5
TA 60
CH 600
CYA 0
CSI -0.12
My CH seems high but not sure if this is from the new plaster. Is this something I need to get a handle on right away? I did notice two small bumps in my plaster, which look like calcium nodules. (Picture attached). Should I bring that up with my PB?
Also, I’m planning on buying some stabilizer this weekend to increase the CYA. Is a range of 30-50 good?
Sorry for all the questions. Thanks for the input!
FC 4
pH 7.5
TA 60
CH 600
CYA 0
CSI -0.12
