Thank You very much for your help thus far.
I added about half the gallon of muriatic acid (20 degree) that I purchased from lowes as you suggested. And put it in the way suggested as well.
I did all the tests again to see what changed. Here are the results:
PH: 7.5
FC: 7
CC: 0
T/A: 120
CH: 625
CYA: 85
Am I ready to go swimming
PH: 7.5
FC: 7
CC: 0
T/A: 120
CH: 625
CYA: 85
PoolMath only does calculations. It does not tell you what to do. That is up to you to decide (with our help for now of course)
That result is not correct. Check the volume you have entered and make sure the TA is set.
Like I said, your CYA is tolerable, unless you want to replace half the water ... figured you did not want to do that given you state's water issues.
