Just opened the pool yesterday - water results are pretty good I think, trying to figure out next step
Results-
FC- 12 ppm
CC - 0 ppm
Calcium - 225 ppm
TA- 120
CYA - 30 to 40
PH - 7.5
Salt - 2800
My plan is to add 4 lbs of CYA - then re test and add if necessary
What should I do about the TA?
Should I just let the FC drift down to 5ppm or so on its own?
Water temp is 58 degrees F - so still pretty cold
Thanks
Results-
FC- 12 ppm
CC - 0 ppm
Calcium - 225 ppm
TA- 120
CYA - 30 to 40
PH - 7.5
Salt - 2800
Thanks
