Hi all from down under
- this is my first post after just receiving my CCL (Clear Choice Labs) test kit.
First a bit of back ground - the pool is now 9mths old, and I would hope has now 'stabilised'.
I've been floundering around between pool shop testing/recommendations and an Aquachek 7 in 1 Test Strip kit - neither ideal I know, but I've got to say the pool has never been anything but sparkling clear - other than regular (maybe 1ltr/week) Hydrochloric Acid dosing (which I believe is 'normal' for a concrete/pebble SWG pool ??) , and intermittent Cynuric Acid, I haven't had the need or been recommended to add much else.
So I unpack my brand new CCL kit, first test is CYA = 50 (Pool shop test has been around 40-45) - OK, not bad I'm thinking for 1st test?
Next test is Free Chlorine = 17
At this point I stop as some research has shown that FC above 10 screws up other testing? ( I did test Salt which came up at 4400).
My Aquacheck strips have always shown 10 (also TC=10 on the test strips) - the pool shop tests sometimes don't show FC result, but when they have, the highest reading I've seen is around 8 - and they have never mentioned anything to me that my chlorine count is high (and until I recently found this site, I wasn't aware that I could have too much chlorine, as long as FC=Total Chlorine??)
I'm currently running pump 8 hours (on lowest eco setting) a day with SWG on 60% (I cut it back a few months ago from the 80% that the pool builder had it set on).
I vaguely remember researching months ago that with the volume of my pool, running the pump on lowest setting would need 8 hours to recirculate the required amount daily?
Should I cut the SWG back to say 40% in an effort to lower FC, and then recommence testing? Do I need to run the pump 8hours on lowest eco setting?
The numbers I've set as target from the Pool School page are :-
FC = 4
pH = 7.5
TA = 70
CH = 400
CYA = 70 (which is bit surprising as I'd always considered 40 to be adequate?)
Salt = 4000 ??
Do these sound reasonable?
Just some additional geographical info for you non-Aussie experts, Darwin is a full-on tropical climate - we have 2 seasons, Wet & Dry. Currently dry season (which is our 'stable' pool season) - we won't see rain for in excess of 7 months. Every day is between 20min & 32max deg C. Wet season is not so good for pools - every day between 27min and 36max deg C (with sapping humidity) and torrential monsoonal downpours that REALLY screw up pool balances, and when we really do need to be chucking 'stuff' in the pool to keep it swimmable.
Looking forward to your thoughts guys - and I promise to not be so verbose next post
FC = 4
pH = 7.5
TA = 70
CH = 400
Salt = 4000 ??
