Our pool is about 18 years old and feel it's time for re-plastering and some updating.
Before I involve any salespersons, I want to learn and understand procedures and options and believe I can accomplish that with your help.
TILE:
I will be replacing the tile around the edge of the pool. I have some ideas of what I would like.
PLASTER:
I want my water color to be a light blue. From everything that I read is that the plaster color then should be a shade of white, gray, or blue.As far as all the plaster add ons such as glass beads, abalone shells and so forth, I think that it would be sufficient to just have a smooth plaster (hopefully that is a less expensive choice).
HAND RAIL:
I am looking to add a hand rail to my pool, but want it to blend in as much as possible and be as inconspicuous as possible.
LIGHTS:
Currently in my pool are 2 small halogen spa type lights. Unfortunately, when the pool was built, I guess I really didn't do my homework on the placement of the lights, the type of lights, and the number of lights to install. Now here I am 18 years later with the 2 small halogen lights in my large swimming pool.
I want Led lighting which is color changing and controlled through Wi-Fi.I am concerned that the area where the lights are housed currently is going to be too small of an area. My question would be : is it possible make that area where the lights are housed a larger area?
GENERAL QUESTIONS:
Following is what seems to be the logical steps in order to remodel and re-plaster my pool. Just trying to educate myself so I will have some confidence when the job takes place. Are these steps in a logical order?
1. Drain pool
2. Drill holes in pool to keep it from popping out of the ground. Question: does this assure me 100% that my pool will not pop out of the ground? And if so, how long can it stay without water? Also, how many holes should be drilled and where should the holes be drilled?
3. Demolition of tile and preparation of pool surfaces. Also possibly increasing the size of where the new lights will be installed.
4. Tile installed
5. Lights installed
6. New plaster applied. What is the proper time to wait before filling the pool with water?
7. Fill pool with water, make necessary chemical applications.
Again, I welcome all your input! Probably goes without saying, but I am a newbie here!
Thanks
Halogen light (there are 2 of these)
Tile missing in several areas
Plaster worn off
Plaster worn off in several places
TILE:
PLASTER:
HAND RAIL:
LIGHTS:
GENERAL QUESTIONS:
1. Drain pool
4. Tile installed
5. Lights installed
Thanks
Plaster worn off
