@Texas Splash @JoyfulNoise @Gotta Pool apologies all for the delay getting back to you and thanks for all the input! I did not record my readings right when I closed it. I see in my logs my last reading was in september but i didn't close it until into october. I know i checked it and chlorine was probably above 10, but i didn't record it into the app. the water level when i closed it was right at where the waterline/wearing off is, which in reference to the skimmer is right at the top screw of the 2 screws you keep the water level between.
I've added some more pictures for reference. based on the location of the wearing I don't think its the auto cover rubbing on it. You can see here that its basically the corner where the cover closes too so the cover doesn't even come close to where its wearing. robot is the Dolphin Nautilus CC Supreme
Also its wearing in the other corner, same side of the pool (hard to see in this pic, but you can see the white area right at the water line in the corner)
and on the opposite side of the pool, no wearing off at all, its like this across this entire side
I as going to make a larger post about this but since I mentioned it above and its already been touched on, I'm really just trying to learn what, if anything, I did wrong on this liner so that when we swap it out with the other one we have, I don't make the same mistakes again. Here are some additional pictures of the wrinkling as well as some kind of sediment/dead algae that never seems to go away....
So if i had to summarize what I've learned so far as a "do/don't do on the next liner" it would be
- open the cover to let the pool breath - we've started opening it daily and also leaving it open while on vacation. what would you say would be the max hours/days to leave it closed for and not cause any issues?
- don't let the water get too hot, it has gotten up to 93+ in the past, again what would be the max temp to not cause issues?
- balanced water - with regards to the different readings, which one would have the most impact on the liner? ph? chlorine? combination?
- don't use magic eraser to clean the waterline gunk
- don't use sunscreen with avobenzone in it - we've read this contributes to the build up on the water line
- test my water daily and adjust the SWG output as needed - I'll admit I was terrible at this initially, I'm trying to do better this year. I was under the wrong impression that having a SWG I could set and forget. This lead to wild swings in chlorine over the past 4 years due to it getting to low and water becoming cloudy to then SLAMing until it was clear again and over compensating by running chloring at 13-15 for long periods of time
any other lessons learned I should add?
thanks again for everyone's help!
