We have a Paramount Paralevel auto-fill that has gotten "stuck" after a couple heavy rains. We have determined this after getting a leak alert from our "smart" water meter and then shutting off the two biggest likely culprits, irrigation and auto-fill, separately. Both times it has been the latter.
Apparently, this is not an uncommon issue when debris get in and the suggested fix is to take it apart, clean, and then replacing O-Rings is suggested. Problem is, I can only find complete auto-fill assemblies for sale - and no need to do that for $1-2 worth of material.
According to the parts diagram (cut & paste), the two O-Rings needed are:
O RING 2-011 VITON DUR 75
O RING 2-020 EP70
An Amazon search turns up so many hits, I still don't know what/if I can just buy something off of there or a local hardware store.
Any help appreciated.
O RING 2-020 EP70
- These look like they might be 5/16 and 7/8" rings, respectively?
- I understand VITON and EP70 are materials and hardness, correct?
- Not sure what the bold '2' is at the beginning of the O-Ring size - any clues?
