Hello, my wife and I purchased our home back in October of last year and inherited the pool the came with it. Its definitely needed some TLC (new liner, new main drain) but we're excited to finally get some use!
While doing the initial startup, I've noticed that there is quite a bit of air being let into the system. The pool is in-ground and has 3 suction inlets: one main drain and 2 skimmers. These 3 pipes come out of the ground about a foot from the pump. They each have an inline valve before they connect to the T to the strainer basket.
If I have only the main drain and one skimmer open, there are no bubbles, but as soon as I add the far skimmer, air is let into the system. I inspected the PVC for the suspect line and could not find any obvious issues. Decided to add some flexible sealing tape around the joints (not threaded) to be safe. The issue still seems to persist, however.
The water level is at least half way up the skimmer and the skimmer does not seem to be creating a vortex or sucking in air.
The system seemed to be properly winterized, but I'm concerned water may have been left in this pipe and cracked it underground.
What would the reasonable next troubleshooting steps be?
Additionally, Can i run off of one skimmer and one main drain for the time being while I troubleshoot this issue? The pump seems perfectly happy with just the 2 inlets. Circulation seems okay, but is obviously diminished.
All help is greatly appreciated! Please let me know if I've left or any important info.
