Hi, finally ran out of tabs and shock and purchased the K 2006C. New here but it looks like my test results should be linked above. I was going to buy bleach and start adding but I want to know if I should address the 100+ CYA first? I tested it twice and it might be a hair higher than 100. Does cold water affect testing? Did the test in the kitchen in the evening under bright lights and I have good eye sight. Any other factors to consider with CYA? 60 degree water and about to get into the 20s in here next week. I dread it but it sounds like draining out some water is my only option. Other than that, I’m starting to get some mild algae growth from lack of chlorine but I figure a brushing will take care of it when I add the chlorine.
Any tips appreciated!
