Pulled the trigger today on a pool package and am thrilled. Had a self installed 24 ft. Doughboy pool many years ago that we did the TFP route. We are 20 years older now and my husband is my kitchen contractor and cabinet builder this summer, so we are having this new pool installed. I have to learn things all over again now! So saltwater systems in an above ground pool are a whole new thing since my last pool. Is it worth it? I can add it, but did not order that today. Wanted to do research first. Some things do not change-such as makes and models of pools might as well be mattresses when you try to compare.
The pool I chose is 18 ft. round, 54” Resin frame with aluminum walls. 25 mil beaded liner, 2 hp pump, some hybrid type of filter that is out of my wheelhouse (had a giant sand filter before), package with all the covers and maintenance stuff, ladder steps that can pull up and lock, install included into a sloped yard. 7100.00 all in. I know I could do steel walls cheaper but prefer the aluminum with resin. Install hopefully May but probably June.
