Here is our design and specs. The pool is about 17 x 34 including a bench all the way around. Any feedback is appreciated. Pool plan-flat.pdf.
Specific questions - skimmers - should we have more than one? Where should they be? Lights - is one enough? Depth suggestions for the bench around the pool? We are planning to finish with AquaBright. Does that change anything or is it just an added step at the end? Does the AB installer also do the plaster or is that two separate subs? We plan to put solar heating on the roof. The person doing our plans doesn't do plans for solar heating (we were just informed of this). Can we still plan for it during the build or do we just make that phase 2 of the project? The person doing the plans did the specs on the equipment. Would you change or add anything? We are removing a slope and adding a 5 foot retaining wall on the left side of the pool. Anything we should consider with that? Thanks so much for your help!
