Final plumbing outcome
Sws
74
Long Island Ny
I figured Id share my setup since I did it with a lot of info obtained here.
The pump and filter were originally done with some cheap hoses. I built the pad, added the heater and buried everything. This is my first time working with PVC piping and pool equipment so being an amateur is an understatement. The equipment is probably the cheapest of the cheap because that's what it came with. Over time, ill do the filter and pump but this years priority was the heater. Next year ill add the chlorinator.
Considerations were:
1 make it functionality correct
2 keep it as simple as possible
3 make it easy to disassemble for winter storage
4 keep room to work on equipment
5 have a bypass on the heater
6 have the recommended 3ft between heater and future chlorinator
7 have future chlorinator installed vertically per manufacturer recommendation
The only thing I would really have done differently is extend the pad another 6" out to keep all of the plumbing over the pad. I may to a paver border to address that.
  • Love
Reactions: Newdude and pjt
Pretty clean...
Did you leave 6" between heater and fence? Is that fence plastic?
Yea. I have about 8" there.
I bought some heat shield incase it gets too hot.
This heater also won't be on all the time. My plan is to use it for an hour or to in the AM to take the chill out of the pool. I work evenings so I'm gone when its at its warmest.
My pad is covered and in a hutch. It has wood panneling. Whenever I drain the filter...it is a pain because the drain is in the center bottom of the filter (hard to reach), and it makes a mess in the room.
I have this on my list to put on my filter this year, so it is easier to drain and not such a mess.
