Filtering water for liner measurement when level is low
kbert1676
1
Wisconsin
Hi all..
I am getting my vinyl line replaced in my 17'x32' in-ground pool due to it just being old and starting to leak. The company that I am working with, is sayingthat the water needs to be clear before they will come out a measure (I believe a laser measuring system). Question is: Since my pool leaks, and the water level is low (below skimmer) is there a way to use an above-ground pool filter for the 3-4 days to get the water clear prior to draining for replacement? I am struggling with filling/filtering/opening just to drain all that water out.
Suggestions??
Welcome to TFP.
How would you circulate water through an above ground filter?
A filter is the same for an inground or above ground pool.
Is your water clarity problem just filtering or is it algae that needs to be chemically treated?
Post pics of your pool so we can see your current situation.
