First off, thank you to all the members of this community. I have never had a pool and the depth, breadth, and wealth of knowledge shared by people on here is truly amazing. This newbie is truly appreciative, especially the BBB method. Now trips to walmart instead of the pool store
I have a Pentair sd80 filter (3.15 sqft, 70 gpm) that is 3 years old and just found that it sprang a leak near the seam at top. It is clearly a hole in the housing and now way associated with a seal or fitting. After reviewing several threads, this seems to be a fairly common problem associated with Pentair.
Anyways, one of the things that I have noticed, after reading through many of the threads is that, most people have a pressure readings are in the 15-25 psi range. When our system was installed, it was reading 30 psi at start up. We would wait and backwash when the psi got to 38-40 range and it would drop back to 30-31. I thought that this was just it's "normal operating" range. I also, this spring, did a deep cleaning on the sand filter and again the psi stayed in 30-40 range. I have all my skimmer lines and return lines fully opened.
My question would be.... If I went to a larger filter, say a filter in the 4.7-4.9 sqft and 100gpm range, would that drop the pressure down at the filter. Since my filter sprang a leak, I am hesistant to return with the same filter and have the same higher operating pressures.
