I am new to pool maintenance so any help will be appreciated.
When the pump on my pool runs, water drips into the backwash drain. I assume this is an issue with the filter? Could it be anything else and if so, how can I fix it?
The filter is a purex SMBW 2060 - old steel model which up until recently has been working.
1. I assume the filter is not worth repairing and is probably best to buy a new one?
2. Can anyone suggest/recommend a replacement? One that will be simplest/easiest to install (i.e. the one which has connection points closest to my existing filter)?
3. Best online company to purchase the filter from?
4. Multi-port or push-pull valve?
Thank you very much
Regards
Thank you very much
Regards
