Just want to check with the community to see if I'm going about this the best way. I have a new pressure relief assembly and a new drain plug o-ring to install on my DE filter (have leaks at both spots). I recently broke the whole thing down, cleaned well, and loaded up new DE. This was an attempt to fix the drain plug leak with new teflon tape and lubing o-ring (didn't work, now replacing o-ring).
Does it make the most sense to put the multiport valve in recirculate, remove the top relief assembly, remove the drain plug, and let the water drain out, in an effort to retain as much DE as possible? I want to take the grids out to access the female threads at the drain plug while retaining the DE on the grids.
