- Jun 24, 2021
- 17,374
- Vinyl
- CircuPool RJ-60 Plus
So, for those that have followed, new pool owner. 31,000 Gallon in-ground. I was pool stored, now complete TFP convert. Chems are easy, less than 5 minutes a day. Now I turn to my filter and pump. Will replace/upgrade this fall if necessary. Also will re-plumb. Would like to get input.
FILTER/PUMP
Pool Store sold me Zeolite. It has worked well for me, but I'm going to convert back to sand (US Mystic White II), as I don't want to mess with re-charge etc. The Filter is a Pentair S7S50. Filter Area 2.4 Ft. Flow Rage Range 33-48 GPM. (See attached specs). Pump is a Pentair VS pump, 342001, Line 392 here: Pump DB. Also see attached specs. I usually run the pump at 1400 for 20 hours and 2200 for 4 hours when I chlorinate (Stenner Pump) on timer. I will likely reduce the amount of pump time when I have time to study more, but for now, it works and I don't mind the few $$. The focus is on the filter size and pump combo.
I have two skimmers. One is about 20' from equipment, 3 foot rise, one is 30' 3 foot rise. Two returns, one is 20', 5' rise, one is probably 80' with an 8' rise. All plumbing is 1 1/2" corrugated plastic, except for the pad area, all is smooth. (see picture). How do I figure out total dynamic head. I have no idea how to figure out Total Dynamic Head to figure out GPM/GPH from my setup.
Generally I've been happy with the setup, it has worked well. Pool is great no issues.
I also included a picture of the setup.
Here are my questions:
1) is this sand filter big enough, or should I get something larger?
2) is this pump sufficient? What are the right speeds to run the pump with this filter?
3) I had a UV filter, which I tore out, that is the top and bottom valve, currently using the bypass they put in. I also tore out Puckinator (you can see black line from input to output that I just removed chlorinator and connected input to output. I also put it line for Stenner pump you can see on return elbow (which I will replace with 1/2" NPT "T." I'm going to tear all that out and replace. Any recommendations on where to put unions or how to re-plumb efficiently? Will keep the bypass on the heater. Other union recommendations?
4) Any other recommendations?
Thanks TFP for all the help!
FILTER/PUMP
