I have a Pentair Sand Dollar Sand Filter (SD35) for my 5,000 gallon above ground pool. Several weeks ago, I had a local company change the sand in the filter. Before I get into a discussion with them, I would like to have some opinions as to what the problem(s) is.
Ever since then I have been having the following problems:
- When I backwash, only clear water comes out of the backwash hose. Normally, when the pressure increases by 10 psi (from 10 to 20 psi), there is filtered stuff from the pool which is washed out of the filter.
- After backwashing, the psi is 10, however after about 2 hours or so of ‘filtering’ the psi increases to 20. There is no sand being expelled into the pool.
- I had an algae outbreak (sue to a health issue I couldn’t work on the pool). I shocked the pool, killed the green algae and the water is blue again. However, the water is cloudy (white cloud). I have tried clarifier with no success. This may be due to the filter not filtering correctly. Another possibility is a high calcium level. However, we live in the desert and our normal hose water is hard – high in calcium. Any suggestions?
