- Jun 11, 2024
- 4
- Plaster
- Pentair Intellichlor IC-40
Hello, I'm trying to understand what this filter pressure should be reading. Wasn't quite sure what to search for (was searching "low pressure").
TLDR: is my pressure reading ok (image attached)?
It is a Pentair clean and clear cartridge filter.
If I run max (3450) the highest pressure reading is 28 psi I guess. Running 2550 is about 15 psi. The gauge has "start" and "clean filter" 30ish and 40ish respectively. I just swapped my about 9 month old filter just incase that was an issue.
Thank you in advance
