So I have a 21 ft above ground pool that I installed last year. Last year everything was working great. I winterized the pool and got it all ready this spring, but the only problem is the large sand filter keeps getting air inside. I have trouble getting the pump to fill the filter up, but even when I do once it runs a while it ends up filled with air. When I turn off the pump all the air rushes back through the pump and out the skimmer and bubbles quite aggressively for a couple seconds. Any thoughts on what the issue may be? (when it is running it seems to be running fine with the proper pressure and circulation)
Thanks
Thanks
