when it fills back up get your chlorine back where it is supposed to be until you pass all three tests for the SLAM, relax and just vacuum to waste until you get rid of this stuff. it is obviously too fine for your sand so just dump it one step. when most is gone and you are close to the end of the slam you can try DE in the filter...BUT!!! read and understand and follow the directions carefully.
have you tried disposable hairnets or a skimmer sock? they pick up a surprising amount of fine crud and helps keep your main filter cleaner.
