I have a filter that has a 2inch inlet/outlet; but confused as to my pipe size - if I am using 50mm pipe size is that a match for the 2 inch inlet or I should be using 63mm and that would be an exact match?
epco provides pvc pipe dimensions including outer diameter, inner pipe diameter and wall thickness so that you can better choose the pipe that's right for your job.
