Hi all,
I have just finished installing my above ground pool and I am currently filling it up.
I just purchased my bleach from Sams. It is Clorox 8.3%.
I have also purchased the correct test kit in order to balance the water correctly.
I have read over the most of the basics here, so I feel I have an OK understanding of what I should do.
At this point though, as the water is about half-way up, should I do anything yet, like test the water or add the bleach or should I wait until the pool fills all the way and I start running the filter.
I believe I also read that you should first start with adding the chlorine before trying to raise any other levels up or down, would that be correct?
Thanks so much
Thanks so much
