I just got a hand me down saluspa. I've seen how to put air in without draining the spa. But What if you don't have the air hose? I was gifted my spa and I dont have that part/he air hose (which appears unorderable) nor do i have the caps to go inside although i was able to order those and 1 is on the way and 2 backordered.
I bought a little coleman pump that filled it up just fine empty. When full of water, Can you leave everything connected and just fill the air hole using the pump without removing water since I won't be using the pump/heater unit to fill it with air?
