I have what appears to be a FibroPool 3-way valve (with Pentair actuator) that is leaking under high pressure. I think it's this one: 3 Way POSI-Close Valve. See attached pic.
It only leaks noticeably in Spa mode; it doesn't leak in Pool mode, which is why it seems like it's pressure-induced. I assume a gasket has failed. I only noticed this because central Texas is experiencing a freeze, and I noticed a large icicle descending from the valve. I also notice some air coming from the spa jets, which I assume is related.
Anyone have experience with these valves? Do they make a repair kit? I've reached out to FibroPool but I don't expect much.
If it needs to be replaced, what is a reliable alternative?
