The other day I wiped the side wall of the pool, below the water line and the white rag came out of the water stained the same blue color of the pool. I did contact the manufacturer and filled out warranty paper work. The pool does have a whitish color when I do a drain, however the pool looks normal when filled to proper level. The guy at Leisure pool thought the gel coat is "softening up". My concern now, IS THIS POOL SAFE TO SWIM IN?
The chemistry as of yesterday is as follows.
FC 4.6
CC .2
TA 225
CH 250
PH 8.0
CY 30
CSI .7
Just before this post I did a vacuum to waste and refill, so I will have updated numbers this evening. ( I do realize ph/ta high, cy a little low)
Has anyone ever dealt with this happening before??
FC 4.6
CC .2
TA 225
CH 250
PH 8.0
CY 30
CSI .7
