Fiber Clear Addition
Ribbod
0
May 30, 2018
143
Marietta/ga
I just added 3 scoops of "Fiber Clear" to my skimmer and nothing has happened... no change in filter pressure... do I keep adding until I see a change in my PSI? The bag was opened in my garage (from prior home owners) - is it possible it could be bad/too old?
May I ask why you are adding fiber clear to your sand filter?
Is there a problem with your water clarity?
With DE you are supposed to add it until you see a 1psi rise, I would think the same might be true for the fiber, although it does behave a little differently.
