- Jul 21, 2013
- 53,274
- Plaster
- Pentair Intellichlor IC-60
Ok....what about everything else....plumbing, filter housing, SWCG, automatic valves., etc. etc
What about are you asking?
The PVC lines, the control panel, the SWCG...if we lose power, should they be wrapped in towels, covered in blankets, etc. etc. Once power goes out I am going to throw the breaker to the panel so the pumps won't start by themselves. So can we cover them. My question is should we wrap/cover pool equipment once it is drained and power is out???What about are you asking?
That is my plan. It’s covered now in a tent to keep the wind off. Blankets and tarps are on everything except for pumps. If power goes out, I’ll drain everything and recover to include the pumps.The PVC lines, the control panel, the SWCG...if we lose power, should they be wrapped in towels, covered in blankets, etc. etc. Once power goes out I am going to throw the breaker to the panel so the pumps won't start by themselves. So can we cover them. My question is should we wrap/cover pool equipment once it is drained and power is out???
From what ercot is saying the rolling blackouts will be only 15 minutes and the power back on for a couple hours. I think just leaving the main pump/spa and water feature pumps on is about all you need to do. The lines aren’t going to freeze solid in 15 minutes.Sounds like it is only a matter of time before we 'lose' (city pulling the plug) power. Once it does Ill throw breaker, drain and wrap. Thanks!
We’ve had below freezing temps for three days now. It’s 6 degrees currently and the high on Monday is 4 with a low of -5. Add -25 degree windchill to that day. Temps won’t creep above freezing until possibly next Saturday. Not normal for Tulsa at all. That’s the only reason I’m wrapping everything up in the tent (my tarp/tent combo). I use a construction lamp to “warm” the pad at night and a small heater during the day. It keeps it at a steady 20 degrees for now. I think you’re right that it probably wouldn’t be necessary for a few hours. Unfortunately, we’ve got a long way to go.I don't see what the point of wrapping the equipment would be once the water is drained from it. Not necessary IMHO.
Also, if temperatures are only going to below freezing for a few hours, that is not enough time for freeze damage.
Thx. Just hoping to keep things running at this point.If you have multiple days of sub-freezing temps, the best thing to do is to just drain the equipment. After that, there is no point to tarping/covering. It doesn't add anything.
Yep...trying to decide to go ahead with Plan B and draining the pad now. If one skimmer ices up but I can still pull water through the bottom drain, is it smarter to keep everything running? Currently, the main pump looks ice-free, the fountain pump is working well, and the booster pump running some jet seats in the spa is running well. Very little ice in spillover spa. Ice is forming on the pool but not near the moving waterfalls, spillover, or bubblers.Everything is fine running pool pumps 24/7 when temp drops below freezing. Circulating water is harder to freeze. Water is slightly warmed up when pumped. Electronics are generating heat...all goes to heck when the power goes out.
