I just installed an SWCG and am considering whether to repurpose the chlorine Stenner pump for Muriatic Acid injections. I have a 15 gallon drum that would have to be emptied and cleaned, but don't really need or want to keep that much MA around, nor do I really want it inside the pool pumphouse where it can corrode things. We use about a gallon of MA a month. I was thinking of just feeding the MA straight from the gallon jugs it comes in by drilling a hole in a cap for the feed tube. Has anyone done this? It eliminates handling/pouring of acid, at the cost of having to check and switch jugs every month or so.
When I installed the SWCG, I put in a second injection point tee, so I have the option of injecting before or after the SWCG. From other threads, it seems best to inject acid after, since while acid is used to clean the cell, it's better to do that intentionally when needed than to risk overdosing and reducing the cell life that way. Which side do those of you who have both an SWCG and MA injection use?
